Old 04-15-2012, 06:36 PM   #23 (permalink)
redorchestra
heading for 40
redorchestra's Avatar
Hong Kong MTR - '98 Bombardier/ nee Adtranz A-Stock 5 paired doors
90 day: 102.63 mpg (US)
Originally Posted by NickelB NL View Post
For my car i am planning a alu 1x1 square rigid frame with attachments every 20 25 inch. And then alu sheets rivit on the frame. And under the engine a sheet rivit to a single frame witch is bolted on. Maybe a little more expencive. But heat proof, rigit and practicly completly flat. And then on the sides also from sheet wheel wide skirts lower than de belly pan
also a pita to get on or off. even if I could afford to do it RIGHT, I want an easy on easy off. when I go to a mechanic they treat me strange because I am a bit awkward, I don't need them knowing every little weird thing I do! :P
I am also trying to keep it easy to return to stock. nothing permanent!
does my sig work now?
