It depends on the climate. If temperatures go much below zero C then they often mix number one diesel in with the regular diesel.
If temps do not go below zero very much, then the formula does not change.
I lived in an area where -20 C was pretty common. In winter I expected 20 percent worse mileage.
I found the white bottle PowerService helped restore that mileage somewhat and also made for easier starting.
