Old 04-17-2012, 10:50 PM   #2 (permalink)
hawk2100n
The 'Vic - '96 Honda Civic DX
90 day: 39.3 mpg (US)
Originally Posted by mikehallbackhoe View Post
my carbureted crx has a 1 3/8" hose going to the exhaust manifold . it is vacuum operated to open when the engine is cold. I am considering fixing it where it is open all the time. the problem is, it raises a flap that closes off the main air tube, which is 2" diameter. I could remove the flap , allowing it to get air from both sources, or partially block the 2" tube, allowing it to draw air from both. any suggestions?
If you are properly hyper miling I don't think you will be restricted much. But opening it partially so that it draws air in from both sources would probably be wisest. Carbs are very sensitive to additional vacuum which acts like a choke. Get some warm air in there without too much restriction.
Civic Build Thread
Your grammar is appreciated.
3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires
