Originally Posted by chrisoverson
I'm not using anything except the fuel usage monitor I've made with an arduino. I want to fit a vacuum gauge but haven't yet, is that what I need?
Your better way to gauge load will be with a vacuum gauge rather than throttle... use the search function of this site in the upper left hand corner and search for how to use a vacuum gauge for driving with load and P&G. There was a thread recently.
After reading about my engine management system it appears the injectors are always live and the ECU pulses the injectors to earth to trigger them. Could I therefore have them on a switch inside the car that I can activate to connect the injectors directly to battery live so as to effectively disable them?
Then on a glide I could flick the switch to effectively stop any fuel from being injected but keep all electronics going, then turn the injectors back on again for the next pulse.
This had been done. I have one too. Search for injector kill switch installs for your model here on ecomodder...
Eventually I would work to automate this somehow, but would this work for the moment? Also should I be aiming to do 50-60 rather than 50-70mph? Thanks!
Closer to 55 mph is better for cruise, as long as it is safe, You might pulse to 65 and glide to 55. That's what I do, seeking to average 60mph (a mile a minute).
Good luck... you'll get it... I did (mostly).
