Old 04-19-2012, 05:19 PM   #71 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by Dieselman View Post
Not quite correct. An open EGR valve reduces pumping losses due to the restriction caused by the throttle flap, without allowing any more oxygen into the cylinders.
We are talking about a gas (petrol) engine here right? as the diesel technically does not have a throttle plate because it does not need to operate at a specific air fuel ratio. Therefore both posts may be correct. EGR hurts mileage in some diesels but may help low load mpg in gasoline vehicles due to reduced pumping losses.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
