Old 04-19-2012, 06:09 PM   #3 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by mikehallbackhoe View Post
most vehicles recommend running the rear tires a couple of psi lower than the front. when you run the max psi, do you run it all the way around, or run the back a few psi lower?
If there isn't much weight on the rear - or the shocks have seen better days - the rear wheels may become a bit bouncy rather than just rolling hard.
With max. sidewall pressure all around, and a lot of weight removed from the trunk, the rear got a bit bouncy, so I'll back off the rear pressures a bit.
For MOT, I'll have to take the pressures down to spec, as it nearly failed the bouncing test last year.
