Old 04-19-2012, 01:50 PM   #1 (permalink)
mikehallbackhoe
honda crx - '84 honda crx 1300
90 day: 55.83 mpg (US)
air pressure, front and back
most vehicles recommend running the rear tires a couple of psi lower than the front. when you run the max psi, do you run it all the way around, or run the back a few psi lower?
Old 04-19-2012, 02:51 PM   #2 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
I run the same pressures because I like my cars to oversteer. If you use OEM pressure distribution car will most likely understeer which is safer for average driver... You can find that out with testing which works well for you.
https://www.linkedin.com/in/vesatiainen/
Developing next gen wheels and tires which will give 20% more range in Tesla Model Y.
Old 04-19-2012, 06:09 PM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
If there isn't much weight on the rear - or the shocks have seen better days - the rear wheels may become a bit bouncy rather than just rolling hard.
With max. sidewall pressure all around, and a lot of weight removed from the trunk, the rear got a bit bouncy, so I'll back off the rear pressures a bit.
For MOT, I'll have to take the pressures down to spec, as it nearly failed the bouncing test last year.
Old 04-20-2012, 01:25 AM   #4 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Yes for MOT I always lower the pressures to 2.0 bars on each corner. Specially with older vehicles that is very important thing. It might show failure even the shocks being ok. Its same with other stiff aftermarket suspensions that the test might fail even the suspension would be new!
Old 04-21-2012, 06:44 PM   #5 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
I run 43 (nitro) on all four corners and have no problem, but the the Q45 Sport was an electronicly adjusting suspension.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
