Originally Posted by dcb
...It was noted that with the key off, cars were looking to the guino like the injector was stuck open. So if the injector is open for a "rediculously" long (1.5 seconds) time then we start the clock on the LED Backlight shutdown....
Well, it was worth a try anyway
I installed one in a 98 metro 1 liter and guess what? When you use a kill switch to stop the engine, the injector signal floats low, or something. I EOC it, and after 1.5 seconds the MPG (and mileage tracking) go to zero, and after 15 seconds the screen blanks. I don't want to introduce an extra installation wire to determine if the key is off, so I will just time out the backlight and current trip after 10 minutes of vss/injector inactivity. Is 10 minutes ok? do I hear 5? or 15?
