Old 04-21-2012, 09:03 AM   #44 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by pete c View Post
Diesels burn next to nothing at idle. Any restart adds some sort of wear and uses battery power, unless bump starting a manual.
Therefore, I would think that leaving it running for up to a minute or two makes sense.
My TD's lowest idle usage is 0.52-0.54 liters per hour after warming up and without extra loads. With lights, radio, ventilation, and/or A/C that can easily get to 0.80-1.20 lph. I've checked in 2-3 gassers with similarly sized engines that they have the same fuel consumption at idle, so it's about even. If one is worth shutting off, then so is the other.
The Following User Says Thank You to Piwoslaw For This Useful Post:
Frank Lee (04-21-2012)
