Old 04-19-2012, 05:52 PM   #41 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by JanvdW View Post
I tested the "theory", and got no assistance from the servo, at 400 000km and 14 years of service, the system may need some attention.
I can't get 3 stops from a modest 30-35 kph out of my 2005 Volvo - so much for the theory.
Tried it in stop & go traffic downhill, and had to stand on the brakes just to get it stopped the third time.
Good to know I'll only have one shot at stopping the car in an emergency though.
Old 04-20-2012, 03:38 AM   #42 (permalink)
ZX - '97 Citroen ZX Monaco
OldContinents
90 day: 61.05 mpg (US)
That is really odd, I get three stops in my car (actually 3 of my cars) and it is general rule, minimum would be one full stop, imo.
But certainly better test that to be sure, also I think it could be possible to add vacuum reservoir of some sorts? That would improve safety of EOC for vehicles that fail to have enough vacuum reserves.
edit: I did check the law and it is two braking events that law requires at minimum. Your country may vary.
Old 04-21-2012, 07:37 AM   #43 (permalink)
Diesels burn next to nothing at idle. Any restart adds some sort of wear and uses battery power, unless bump starting a manual.
Therefore, I would think that leaving it running for up to a minute or two makes sense.
Old 04-21-2012, 09:03 AM   #44 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
My TD's lowest idle usage is 0.52-0.54 liters per hour after warming up and without extra loads. With lights, radio, ventilation, and/or A/C that can easily get to 0.80-1.20 lph. I've checked in 2-3 gassers with similarly sized engines that they have the same fuel consumption at idle, so it's about even. If one is worth shutting off, then so is the other.
The Following User Says Thank You to Piwoslaw For This Useful Post:
Frank Lee (04-21-2012)
Old 04-21-2012, 01:17 PM   #45 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by Piwoslaw View Post
My TD's lowest idle usage is 0.52-0.54 liters per hour after warming up and without extra loads.....I've checked in 2-3 gassers with similarly sized engines that they have the same fuel consumption at idle, so it's about even. If one is worth shutting off, then so is the other.
My buddy's 2006 VW 2.0T gasser shows 1.0-1.2 liters per hour fully warmed up, no extra loads. That's double the consumption of your diesel. That's significant.
Old 04-21-2012, 02:42 PM   #46 (permalink)
Everyone seems to think that and so we end up with everyone idling for waaaaay more than a minute or two. Always.
Old 04-21-2012, 04:00 PM   #47 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
not going to disagree with you Frank. I do do my part, but you are correct. I observe far too many idling diesels.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 07-01-2012, 07:25 PM   #48 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
here in cal. our trucks at work have an auto shut off at 5 min of idling (the state side not the military)
Old 07-01-2012, 07:47 PM   #49 (permalink)
mechman600's Avatar
Most "Clean Idle Certified" HD engines require a 5 min shutdown timer. Cummins engines do not, as they idle clean enough to not require it.
Old 07-01-2012, 07:55 PM   #50 (permalink)
ron
I may be wrong here but I think cal. has a law if you are not moving the engine is required to shut down after 5 min. for smog
