Originally Posted by t vago
My final point is this:
ices to run using steam, folks. You're only hurting the cause of ecomodding.
it is ok to just say you don't know how to do the math either.
you are pretty good at doing the easy math at atmospheric pressure using engineering 101 tables.
better then I am by far.
can someone help with the math of my final example?
thanks!
doug
