Old 04-23-2012, 04:26 PM   #1 (permalink)
Gone2
Trying to get going again (ignition switch problems - '97 Nissan Sentra)
I have a 1997 Sentra that has been very good on gas, but is now giving me problems. I found that the ignition switch had some problems, and was actuating the switch out of the column, when I accidentally bumped the metal under dash frame. Of course it sparked, but now the switch does nothing, I swapped in a new switch and still nothing. All fuses seem to be good, and I will swap the Ignition Relay switch to see if that does anything. Aside that, what else is there to check on these cars?
