Old 04-24-2012, 12:23 PM   #117 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by tjts1 View Post
What a cluster f#$% over something so easy to test. I suppose endlessly arguing about it on the internet consumes less gas than actually testing it in real life. I tested it and it definitely reduced injector duty cycle. I'm pulling together the parts for a more permanent rig that I can actually drive around with.
I guess you don't want to have your logs examined, after all.
Good luck with with your setup. It'd be interesting to hear your results.
Just one quick question, though - did you run your test while the engine was under gar and under a real load, or did you run your test while the car was parked?
