Old 04-26-2012, 01:56 PM   #11 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by pete c View Post
I think running without the alternator for shorter trips is a very good idea. Using a portable PV array to help keep it topped off is also a good idea, but, I wonder if it's worth the cost and trouble? I think it may be if you remain parked for long enough stretches to provide a substantial charging. How long that period of time is, I have no idea. Depends on the size of the array and the strength of the sunlight.
Here is an older thread on this theme, check out Ryland's post (#2) in particular): http://ecomodder.com/forum/showthrea...ons-17009.html
I think a better idea is active management of when the alternator is used and use of deep cycle batteries. A simple way would be to toggle it on with the brake light signal. An accurate voltmeter would tell you when your charge was getting low enough to need to go to full time alternator use.
This is a good idea if you drive your car engine on a lot and in the city. If you do a lot of engine off coasting, using the brakes won't engage the alternator. And if you drive a lot of the freeways (not in bumper-to-bumper traffic) a brake-activated system might not be ideal or even practical.
james
