Old 04-27-2012, 01:57 PM   #13 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by big shafe View Post
Ok crap I forgot to sum up the cylinders, so the 4cyl does have more surface area. Only about 2% more, not 50%.
The math that you did only shows part the heat rejection process inside a cylinder.
For example, the "core" heat of the larger diameter cylinder is higher in temperature than the smaller diameter cylinder, and this in turn allows less heat to escape to the outside cylinder wall during operation.
This is why a single cylinder engine of the same displacement will always show a theoretical improvement in engine operating efficiency over a multi-cylinder engine.
What Mr Miller pointed out earlier, multi engines are preferred for more power output, since they allow higher valve area per cylinder volume, and higher rpm's, BUT at a lower operating efficiency. Back in the late 60's Honda was famous for it's family of multi-cylinder race engines, including a 250cc 6-cylinder.
This is why locomotive engines employ such large piston diameters; higher core cylinder heat and less cylinder wall losses.
I work with pressure decay leak testers, and this effect is very important to accurately setting up these testers for proper leak-down numbers. When you pressurize a part for leak down testing, the internal air heats up, and you need to allow for this heat to normalize before making a proper leak down measurement. The larger the part, the more core heat it has and the wait time for this heat to dissipate is not linear, strictly based on volume. The part shape also dictates surface area, and also affects heat rejection to the outside.
All things being equal the 4 cylinder should out-perform the 8 cylinder in efficiency.
Jim.
The Following 2 Users Say Thank You to 3-Wheeler For This Useful Post:
Frank Lee (04-27-2012), Regenerit (04-27-2012)
