Originally Posted by steffen707
I just went back and looked at the first page of this thread. I didn't realize you used a washer as well. I thought you found a switch that perfectly fit into the hole.  Basically i completely copied you. And if somebody didn't want to use the rubber gasket, you could just wrap a ton of electrical tape around the barrel of the switch until its just a bit tight.
This setup is super slick though and I love the factory look. Even if you don't have a civic, you can use the civic shifter mod on your car with similar results.
Totally cool. Thanks for the pics. I had thought of using black caulk to plug up that hole for the screw on the auto trans selector, but my caulk dried up and I'm too cheap on that minor point. Well... back to work, lunch over! (hear that, employer of mine?)
