Old 04-27-2012, 03:02 PM   #3 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Welcome to the forum.
I know my air filter could be changed but i have been blowing it out every so often.
Believe it or not, a dirty air filter will have a little to no effect on fuel economy. Long gone are the days when a dirty filter accidentally resulted in an enriched air/fuel mixture (pre-computer monitoring - e.g. OBD). Even with a dirty filter, at part throttle openings (ie. at low/mid load engine operation), the throttle plate is the major restriction.
Some things that caught my eye are under body aerodynamics, grille blocking, and rear diffusers. All pretty subtle if done right.
Those all sound reasonable. I'd start with the partial grille block (easiest), and monitor engine temps as you progressively tune it for best effect. Do you have a way to accurately monitor coolant temps (digital gauge)?
