Originally Posted by chrisoverson
What about issues with stopping distances etc?
It depends on the tire. Ride comfort was mentioned before and that's a big part of it. Tires are far superior than they were back in the day and are much less sensitive to changes in pressure. But I wouldn't recommend going much over 10% over your maximum sidewall pressure. Definitely not 50 psi. Overinflated tires can still be victims of uneven wear but it is a problem with wider tires that require the steel belts in them to be flatter than the little donuts that most people like to run on this site. My little 175/70r13s are not very susceptible to that where a 255 in a truck tire will be able to bow out in the center easier. Keep them inflated but not too high. Don't ever let them get low. That's free gas you're wasting.
Civic Build Thread
Your grammar is appreciated.
3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires
