Originally Posted by Christ
Roots blowers generally use a helix type rotor design to help smooth the pulses out. Only very old designs use "impulse" style charging, because it creates a pulse frequency that can make proper fueling very difficult.
Thus, there's really no way to "time" the pressure pulses exactly to a specific event, since the design is meant to provide steady pressure, rather than pulsed pressure.
Even if you designed a blower that provided pulses, it would only serve to enhance the effects of helmholtz tuning (frequency-based freeair supercharging), and wouldn't provide much of an efficiency gain over just charging and maintaining pressure in the intake tract.
Purely hypothetetical. But yes I would specify a roots blower instead of a screw type. But who knows what it would do. You would only have a slight gain over a similar setup at the resonant frequency. Really none of this applies because superchargers don't improve efficiency but power. The work I have done with engines is in the racing sphere and that is very different than efficiency. Max power has been driven into my head.
Civic Build Thread
Your grammar is appreciated.
3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires
