Old 04-28-2012, 12:30 AM   #26 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by big shafe View Post
Do you have any or can point me to any data that supports this? I would think temperature gradients would be hard to quantify. I also think it would be highly dependent on fuel/air mixture distribution and fluid flow characteristics.
I could possibly see that for similar compression ratio's but not sure about large compression ratio differences.
I remember as a kid, we had a toy that contained about 6 plastic eggs, the smallest one inside the next bigger one and so on.
Now picture the six eggs as being "layers" of freshly heated air inside an engine cylinder.
The smallest egg is the hottest since that egg is insulated by the thermal ability of each larger egg. Each egg is actually a "thermal blanket" insulating the cooler cylinder wall from the "hot egg in the center".
Since we know that the air itself is a natural heat or thermal insulator, the core heat inside the cylinder is maintained longer by more layers of "eggs" to keep the core heat from cooling much.
Now let's correlate our six eggs with a relatively small displacement cylinder. How much longer will the same gas stay hot if we make the cylinder larger by adding more layers of "eggs" to the mix?
What if we now have, in addition to the six layer egg, introduce a nine layer egg as well. Remember, if a layer of egg represents more layers on insulating "air", then the egg with more layers will certainly maintain it's trapped heat longer after the spark plug fires the fuel-air vapor mix. The six layer egg represents a small cylinder size and the nine layer egg equals a larger cylinder.
Our egg experiment is exactly one of the reasons why an engine with larger cylinders maintains it's core heat longer. More egg layers.
Jim.
