Old 04-28-2012, 04:06 PM   #10 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by mikehallbackhoe View Post
now that I realize the choke is opened when the voltage heats the spring, which opens the choke, I wonder if coasting allows the spring to cool off, also causing the choke to come on? up here in the mountains I can coast for miles. would I be better off getting a manuel choke?
So you tried adjusting the idle? You're certain its the electric choke? Then I think you have a good idea. Remember though, part of your FE gain will be lost if the added power is used for faster speeds or for less than ideal acceleration conditions. I forget, do you have a vacuum gauge?
