we are getting a little off-topic, but I see there are 4 and 6lb densities available from a manufacturer in Indiana, is this going to be good?
how long does it take to crumble? This is even when clad in glass?
I would not use it in a significant structural role. My hulls are epoxy coated plywood, the cabin structure is what I'm looking at building primarily,
and I need the insulation value as well.
Originally Posted by Stan
Yes, I'm very familiar with this foam. There are several different formulations of urethane foams and this is one of them. And in fact, is exactly what I had in mind when I wrote under Urethane Foam, "Sold as tan-colored closed-cell insulation at home improvement stores."
The challenge with urethane foams is that at low densities and thin sheets they tend to break down over time into dust (literally) under repeated vibration and pounding loads, so I recommend not using them in boat hulls, homebuilt airplanes, car body parts, etc. You live in Sactown, and pvc foam is available at Interstate Plastics for $70 for a 4'x8'x1/4" sheet.
I realize that may give you a bit of sticker shock, but pvc foam is a MUCH better choice, and in the big scheme of things, isn't much compared to the price of a complete boat.
