Originally Posted by AndrewJ
It's working!!! I had the VSS and INJ wires switched like I thought. Oh, and the INJ wire from the ECU won't work. I got the INJ signal from the injector harness in the engine bay, found the wire with a DMM just like dcb said.
Great news AndrewJ. I'm going to have to do the same thing with the injector hookup. I did the multimeter test too over the weekend and I saw the same thing. I didn't have time to rewire though.
This leads me to guess why does the ECU emit constant voltage to the Injector?
AndrewJ, Did you keep the VSS signal connection from the ECU or did you go directly to the sensor like the inejctor?
