Originally Posted by Vekke
Radio + cd player total weight 2.5-3 kg
My Radio has only 1,4kg
I have drilled that undertray straight thrugh the underside with self tapping screws.
Okay ... this isn't a good idea
I wanna bond holder under the car for fitting the smooth undertray.
I have put exhaust pipe insulation to the downpipe but on the underside you dont need it at least with my lupos power and speeds driven.
I should put the thermo tape to end of the car, because my TDI engine has little bit more thermal energy.
How long did it take to remove the dash and what is the correct disassembly order?
Only the dash? ....at first time not more than one hour. But I removed all to delete my Climatronic and I cleaned the cable loop. I also replace the fan. I install one of the biggest pc fans. (ony 400g and 0,5A).
Here is a good order ->
Pimpowski's Polo Page
Do you have installed the elctrical water pump?
What do you think about air duct from the front of the car to the end. So you could increase the pressure on the "air" base on back door.
Small solution for your rear spoiler (Polo Bluemotion):
