Old 05-01-2012, 04:33 PM   #18 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by tjts1 View Post
They got the angle right at the factory.
Not quite. The "right" rear roofline would look a lot like a Prius, or the latest Mercedes E Class coupe (if you prefer a trunk), or like the Chevy Volt (if you prefer a "notched" hatchback style like the 318t).
The effective angle of the rear of the 318t (end of roof to tip of decklid) is ~20 degrees. The glass alone is closer to ~23 degrees.
The ideal angle, per the diagram you posted, is ~13 degrees. Not coincidentally, that's much closer to what you'll find on the Prius, E Class coupe or Volt.
Either way you are increasing the size of the low pressure zone behind the vehicle which is counter productive.
Tuft testing of the 318t would probably show that there turbulence & flow reversal on the rear deck lid. That means flow separation (low pressure wake) starts at a point on the rear glass, not at the trailing edge of the "deck lid". It may seen counterintuitive, but a properly designed batman thing will permit controlled pressure recovery further aft and lower down, and would result in a smaller overall wake.
Given the angle of its rear glass, the 318t needed either a taller rear deck lid, a longer one, or a big-ass spoiler for better aerodynamics from the factory.
(Chevy Volt - GM image)
