Old 05-02-2012, 09:55 PM   #13 (permalink)
smokey442
Back in the day the coolant in the aluminum block, iron head Vega engine became a weak electrolyte causing corrosion of the head gasket and eventual failure. Modern anti-freeze coolant supossed to be formulated to combat this. If you can pass electrical current through the coolant guess what it is. (hint think electrolyte)
The Following User Says Thank You to smokey442 For This Useful Post:
chrisgerman1983 (05-03-2012)
