Old 05-02-2012, 11:52 PM   #217 (permalink)
oil pan 4
Originally Posted by ecomodded View Post
Well to be honest miller it would be stupid easy to do and would ensure you have filtered clean water.
If you disapprove of quality control of the water then so be it. I still will suggest you should filter it before you put the water in your on-board tank.
Why you ask? to remove the minerals and prevent the accumulation of salts.
This is the first time I have seen any one worry about whats in the water other than dirt that can be filtered out.
