Mora,
Sorry for not getting back sooner. Dont' follow this very often.
See attached screenshot. Add the two lines after "Charge Mode"
marked with black line.
For this to work, your charge current needs to be under 3Amps.
Otherwise software automatically sets LZstat bit 2 and throws you back into charge mode. But from what you indicated, this is after charging is done and you don't want to cycle power to get to main screen. Quick & dirty with no switch debouncing, but it should get you to one of the main screens.
Personally, I have my main power input set to +12V ignition. I also feed +12V in from another AC/DC supply but through Oring diode. The AC from supply is plugged into my charger AC. So LCD controller either gets power from supply when charging or ignition in normal operation.
-Chris
