Old 05-07-2012, 09:54 AM   #4 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by pete c View Post
If I think I suspect a fairly short wait, I will bump start. If I suspect a longer one, I will roll up with the engine off, then use the starter.
A smoothly done bump start should cause negligible clutch wear. I use usually do it in 5th gear at 10-15 mph. Just pop the clutch smoothly, then immediately disengage it as 10 mph is way down in the lug zone in 5th gear.
I agree with all of this. I keep the engine off at lights where I expect a 30 second sit. But once waiting, I consider 20 seconds or more good enough.
