Old 05-07-2012, 04:57 PM   #20 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by minispeed View Post
The next big update will be fitting 195 70 14. Since the car revs so high at highway cruise I hope that will improve my mpg. It should also allow longer EOC, also the 155s only have a 34 psi max and I've been running them at 38. They tend to leak put back to 34 but not much lower. I hope that the tire spats will compensate for the 4cm per tire.
I can see going for bigger diameter in these tires, but you might trade some of the FE gains from RPM reductions at highway speeds for FE losses due to wider and heavier tires.
