Thread: Air dams?
Old 05-09-2012, 10:08 AM   #55 (permalink)
woodstock74
TBD - '17 Toyota Corolla LE
Last 3: 36.26 mpg (US)
Starship - '08 Toyota Prius
90 day: 45.24 mpg (US)
Starship Resurrected - '08 Toyota Prius
Originally Posted by skyking View Post
Just found the thread, read through. Sorry to say but *I* think you nailed the proper height with Mk 1 air dam. Good work!
Thanks, was intuition and shear luck! When I checked the ground clearance to the driveway of MkI it was only 1/4" above. So I worked a bit backwards inasmuch as I should have checked the clearance first (measure twice, cut once), but I got away with it in a roundabout way.
