Old 06-02-2008, 07:38 PM   #98 (permalink)
ttoyoda
ttoyoda's Avatar
lots of experience with those and copper
What do you make out of copper? Do you ever need to heat treat to anneal part way thru the job?
I would think that with all the compound curves in the front a very thin aluminium sheet would be strong enough.
from this chart:
http://www.auto-ware.com/techref/sheetweight.htm
Al .0508 inch thick weighs .716 lbs per square foot
Guesstimate 15 square foot area for nose???
= 10.74 lbs.
Which admittedly assumes there is no need for inner bracing.
Plus you could do a brushed finish on it and clear coat it.
That would look sharp.
