Old 06-02-2008, 01:46 PM   #91 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
Fuel log?
Comon' you know you want to.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 06-02-2008, 03:31 PM   #92 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
Originally Posted by mattW View Post
I would make one small change (see attachment) and 11 degree upsweep on the bottom of the tail will further decrease your wake size, produce a little down force and allow you to enter steeper driveways etc... Its a win-win change
Yeah the lower angle keep the drag lower, the higher angle creates a "suction force" back there.. don't want suction...
Old 06-02-2008, 03:32 PM   #93 (permalink)
Veggiedynamics
Originally Posted by AndrewJ View Post
Fuel log?
Yeah ill be doing one, but need to get this tank done first..
Old 06-02-2008, 03:37 PM   #94 (permalink)
Veggiedynamics
Originally Posted by ttoyoda View Post
ebacherville, it looks great. Do you have a picture of the front with the new air holes? also, when you open the hood, does the foam stay on the fenders or does it go up with the hood?
If you want to trim the foam a cheap serrated ginzu style knife works well. Then fill in the open pores with some sort of filler (I don't know if bondo dissolves this kind of foam)
Yep stole a bread knife from the kitchen for foam cuting it works really well.. just let you foam cure fully for over a day.. the foam sometimes has gewy spots in thick spots .. then you have to fefill it with foam over again..
Usually i foam the structure , cut it down then sand it down then refill any large foam pours with more foam.. then sand again and them cover with a very thin coat of bondo to smooth it out. Bondo doesn't dissolve it.. either does fiberglass resin, unless its got to little hardener in it, you need it to set up fast 10 minutes or so, or it will melt the foam if the resin takes longer than 15 minutes to harden.. its kind of odd but works well.. makes it strong too.
The hood is spperate from the fenders.. just like stock for the most part.. t
Yeah ill get some photos of the hole in the front of the nose too forgot to take that picture..
Old 06-02-2008, 04:41 PM   #95 (permalink)
igo
igo's Avatar
Mini Box Truck - '05 Scion Xb
90 day: 32.87 mpg (US)
It FITs - '09 Honda Fit Sport
90 day: 36.2 mpg (US)
Impreza - '13 Subaru Impreza Sport
90 day: 30.92 mpg (US)
The nose looks great, like the gt40 picture someone posted. Keep up with the good work. I look forward to seeing the progress.
Old 06-02-2008, 06:20 PM   #96 (permalink)
ttoyoda's Avatar
ebacherville,
when the shape of the whole car is perfected/finished, there is a window of opportunity to decide to redo all the new panels in metal. That is an excuse to get this:
http://ww2.harborfreight.com/cpi/cta...emnumber=95359
Not as fancy as this:
http://www.metalcrafttools.com/englishwheel.html
But much cheaper (was 199 on sale in springfield MA store)
It works like this
Old 06-02-2008, 06:25 PM   #97 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
english wheel
lots of experience with those and copper
I wouldn't go with metal, you need to add lightness
Old 06-02-2008, 07:38 PM   #98 (permalink)
ttoyoda's Avatar
What do you make out of copper? Do you ever need to heat treat to anneal part way thru the job?
I would think that with all the compound curves in the front a very thin aluminium sheet would be strong enough.
from this chart:
http://www.auto-ware.com/techref/sheetweight.htm
Al .0508 inch thick weighs .716 lbs per square foot
Guesstimate 15 square foot area for nose???
= 10.74 lbs.
Which admittedly assumes there is no need for inner bracing.
Plus you could do a brushed finish on it and clear coat it.
That would look sharp.
Old 06-02-2008, 07:57 PM   #99 (permalink)
Silver EP3 - '02 Honda Civic Si
Originally Posted by ebacherville View Post
still cant belive how tightthis motor sounds for 129,000 miles, sound smoother than many new cars.. This is my first Honda.. Im so impressed that they can make a car get 50MPG thats carbed and 20 years ago.. and 20 years later and 129,000 miles later the motor can sound that good.. WOW!!
Its a Honda thing!
Old 06-02-2008, 08:15 PM   #100 (permalink)
Piaggio Fly 150 - '10 Piaggio Fly 150
90 day: 64.8 mpg (US)
No actually up to the 11 degrees you are lowering drag and lift, after that you will start to increase downforce at the expense of drag. But the 11 degree angle should actually reduce your drag as much as possible (optimised) with the side-effect of reducing lift as well. There will be slightly less pressure under the car but more pressure behind it with that angle so you get the best of both worlds! Going with a flat angle will probably hurt FE compared to the sloped one... Take a look at bajoos, aeroplanes, fish, birds, teardrops, they all angle in on the top and bottom.
Check out my Green Cars Blog and the DIY electric car Wiki. Enjoy!
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
crx hf help need more info, rear wheel skirts RP-CLMBR Aerodynamics 2 07-16-2008 09:24 PM
Repping the old school Hondas - 85 CRX HF 1GCRXHF Introductions 4 06-16-2008 01:14 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
AFS Trinity EXTREME Hybrids!!! cfg83 General Efficiency Discussion 10 01-18-2008 07:15 PM
