Old 05-10-2012, 01:17 AM   #7 (permalink)
nihad
I think I figured out why it wouldnt start. I took out the spark plugs and cleaned them with a wire wheel then I pulled out my compression gauge and check all 3 and they were around 60-65psi why would my compression be so low.. I am guessing it should be around 200-220psi. My car only has 108,000 miles why would this happen so early or is this common..
