05-10-2012, 07:48 PM
#49 (permalink)
Originally Posted by nickdigger
Quick answer for you, nick:
Add a wire to your T68 ecu harness connector, at pin #9. I recommend you de-pin one from a junk yard harness, and add it to yours. (Note: depinning VW harnesses is a b-word). Now run it through a rubber plug in the firewall, near the fuse block. You'll need to remove the 100k resistor from your mpguino, because the signal is low-voltage and does not need to be pulled down. Keep the zener, though.
Next, get your VSS signal from the blue/white (or white/blue) wire at W/1 on the fuse/junction block. It's a 12v-0v signal, so keep the corresponding 100k resistor on the 'guino.
Set your InjTrg to 1 (Rising). As for other settings, i haven't calibrated mine yet. My ballpark guess is around 13000 VSS/mile, and 170,000,000 usec/gal, with maybe a 100 usec InjDelay. But i wont know until after i've burned a few tanks.
Good luck.
P.S. kick yourself for not following through with this 2 years ago.
What is pin 9 on the ecu? Is that the fuel consumption wire that was never run to the dash on the US 1999.5+ tdi?
