Old 05-14-2012, 12:16 AM   #22 (permalink)
user removed
I used a cone shaped fitting and just punched a hole in the brake booster hose and forced the cone shaped fitting in the hole until it was very snug. The hose to the vac gauge was plugged into the cone shaped (tapered) fitting. If you ever removed the gauge, you could fill the hole with some silicone or wrap it with tape.
regards
Mech
