Old 05-13-2012, 10:43 PM   #21 (permalink)
Im trying to hook up a vacuum gauge its a 2 5/8 autometer. I am unsure where to hook it up. i have a 92 hb civic with a 1.5L bone stock I have everything setup but not pulling any vacuum. Anyone know where i can plug it into?
Old 05-13-2012, 11:16 PM   #22 (permalink)
I used a cone shaped fitting and just punched a hole in the brake booster hose and forced the cone shaped fitting in the hole until it was very snug. The hose to the vac gauge was plugged into the cone shaped (tapered) fitting. If you ever removed the gauge, you could fill the hole with some silicone or wrap it with tape.
regards
Mech
Old 05-14-2012, 02:18 AM   #23 (permalink)
thanks for the quick response. Is that the best place to tap into on a civic? just verifying before i splice into the line. Just want the most accurate reading i can get.
Old 05-15-2012, 03:35 PM   #24 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
I would recommend going to an auto parts store, gett a "tee" connector for vacuum hoses and "tee-ing" into the vacuum line that runs to the fuel pressure regulator or the vacuum line feeding the Purge Solenoid (little black cylinder on the backside of the intake manifold).
Old 05-17-2012, 11:35 PM   #25 (permalink)
The car has an aftermarket cruise control that was tapped into the booster line. it doesnt work so i plugged in there. I also tried else where but for some reason needle doesnt move. im guessing gauge is faulty weird because its new.
'93 Civic 40.6 mpg + Harbor Freight utility trailer, Honda CL125, Honda CH80 scoot begreen Introductions 13 08-29-2013 06:37 AM
Civic VX & CX Spark Plug Gap flydude1221 EcoModding Central 9 07-01-2012 05:08 PM
Lost 94 Honda Civic VX! Dave's Civic Duty The Lounge 32 03-26-2010 10:20 AM
95 Civic VX Daox For Sale 8 04-17-2009 10:21 PM
1995 civic vx low mileage engine warranty san diego area fistopher For Sale 2 10-29-2008 11:59 AM
