Old 05-14-2012, 02:28 PM   #5744 (permalink)
jyanof
Joe
Originally Posted by MPaulHolmes View Post
It may be some sort of overcurrent protection coming on. But it doesn't sound like you are drawing hundreds of amps, so one possibility is a wrong sensor that is more sensitive than the lem hass 300-s.
When the overcurrent potentiometer is set to its minimum, my controller would trip the overcurrent protection at about 470A. rotating the pot 90 deg or so allowed the controller to regulate max amps (about 509) without tripping the hardware overcurrent protection unless i did something wacky with the kp/ki values.
But, this was only when flooring it, and as you say, it doesn't sound like this is the case...
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
