Old 05-17-2012, 09:36 PM   #16 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.42 mpg (US)
Originally Posted by smokey442 View Post
Body control module prevents roll starting engine (manual shift trans ) on GM vehicles 1998 and newer. Once running you can kill engine by shutting off fuel pump with key switch on. (pull out fuel pump relay is one technique) Reactivate fuel pump and it will roll start but the key switch has to remain on otherwise security light comes on. On my 1998 Eldorado security light comes on once in awhile and I have to wait 20 min. before I can attempt to restart it. Frustrating.
Before installing my kill switch, I ran a test by pulling the fuel injector fuse. The engine stopped immediately. I put the fuse back in, and key started the engine. So, I wired the kill switch to break the fuel injector fuse circuit.
I have never had problems restarting at speeds from zero to about 60 MPH. The key switch is left on, and I do not get a security light.
