Originally Posted by TomO
I would recommend going to an auto parts store, gett a "tee" connector for vacuum hoses and "tee-ing" into the vacuum line that runs to the fuel pressure regulator or the vacuum line feeding the Purge Solenoid (little black cylinder on the backside of the intake manifold).
The car has an aftermarket cruise control that was tapped into the booster line. it doesnt work so i plugged in there. I also tried else where but for some reason needle doesnt move. im guessing gauge is faulty weird because its new.
