Old 05-19-2012, 09:50 PM   #6 (permalink)
SwamiSalami
Easter McoModder
SwamiSalami's Avatar
'99 Subaru OLL 2.5L - '99 Subaru Outback Legacy Limited
90 day: 22.57 mpg (US)
Rabbit - '08 VW Rabbit S
90 day: 32.93 mpg (US)
Originally Posted by larrybuck View Post
What part of the country will you be living in?
Rustbelt? Muggy must have AC? How much stock mpg do you want to start with?
Bottom line: What is your $ level you have in mind? So many variables!!!
Larry, honestly have no clue where we'll be living in when we get back. That's the beauty of being gov't owned. Pretty much must have a/c (or at least the ability to use it when necessary) because of my youngster. would like to have a four door for the same reason, but i could live with a 2 door. As far as stock mpgs, the minimum I think is acceptable (on 5-19-2012) would be around 35/38 city/highway ISH. Budget at this time is around $8000, of course I would like to spend much less, but also as time goes on, the budget grows.
Originally Posted by California98Civic View Post
I'm just a middle-aged member, not "senior," but in 2.5 years I think you'll see some of these Prius C2 models used at the dealers. There will probably be a used Volt or two (I'll be looking). And hopefully that Ford Fiesta 3-cylinder 1.0L turbo eco-boost will be on the market too (new, at least, if not 1 or 2 years used).
Yea, I'm really excited about the direction cars are going. We're officially winning.
Right now:
I'm willing to sacrifice a few mpgs for personality and fun. I'm really liking the tercel 4wd wagon from the early 80s for several reasons. Hypermiling, I feel like I could get pretty good gas mileage, the car starting out is incredibly unique AND affordable, I'm able to work on simpler cars without all the computer shiz, and once the motor craps out I can try and do a swap of some sort, maybe hire out a garage to do an EV conversion or something.
See...the fact that I'd be paying very little for the car makes it very attractive. I'd be less hesitant to experiment with modifications and I'd also feel better about when something goes wrong with the car.
I'm very excited about inexpensive gas sippers from the 80s/90s, because they're relatively simple mechanically, easy (or cheap) to fix and I won't have to worry about messing it up.
I don't really drive all that much, either.
I like the Toyota Echo kind of.
I think ideally I
