Old 05-21-2012, 12:03 PM   #19 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Ford Man View Post
Thanks Ford Man, but the calculator is not quite precise enough, since inflation pressure can change the diameter a little and I run my tires pumped-up high. And anyway, the real question I am asking is about the disparity between the 8% or 9% speed increase and the 1.9% distance increase that my measurements so far suggest. Does the ECU is process data from the VSS in two different ways? Or does the VSS not supply the data for distance? I didn't find the answer in the service manual. Thanks in advance... james
