Old 05-21-2012, 12:29 PM   #7 (permalink)
gone-ot
...beats walking...
...You cannot depend on specs of the tires as the tire may be worn, or you may be running them at a higher pressure, etc.
...another caveat to be aware of is that *if/when* you attempt to mathematically calculate the distance traveled during each tire rotation -- because of tire deflection (roughly about 0.97) under load -- you'll aways end-up getting a number that's slightly too high. In fact, even the 0.97 number is only a rough approximation, which varies somewhat with manufacturer, tire construction, tire diameter, tire loading, tire inflation pressure and tire temperature.
...you can visualize this tire deflection as the slight "flat spot" you see where the tire is in contact with the pavement.
