It's a parallel hybrid in the reverse of how I had considered one. If you had an EV and you wanted to get long range, you could put a small engine on a setup similar to this and drive at highway speeds in a single gear.
I wonder how it deals with turning scrub; assuming that the single wheel is only pivoting up and down?
