Old 05-23-2012, 04:27 PM   #1 (permalink)
90 day: 70.75 mpg (US)
90 day: 62.14 mpg (US)
Article: Forklift tech builds plug-in "5th wheel" EV pusher for Camry
From: Forklift inspires add-on hybrid device | New Hampshire NEWS02
Gugger said with his device, a Toyota Camry could get 50 to 60 miles per gallon, a nearly 100 percent increase. “Say you had a 20-mile ride to work. By the time you get there, your batteries would be pretty much depleted. Plug them in during the day, and then when you come home, the same thing.”
Not too many technical details other than:
  • hitch-mounted
  • uses a golf cart motor (17 hp peak)
  • single trailer tire
  • 48 volts (4x 12v marine batteries)
  • "through the road" parallel system: can either push the car on its own, or assist the gasoline engine
After more than four years of work and three prototypes, Gugger said he's ready to sell the device's patent and have other people apply the finishing touches. He would also be willing to work with others — perhaps move to a fourth prototype — if he can entice a team of collaborators.
He thinks its shelf price will be around $4,000 to $5,000 and that it will eventually come in three sizes.
He justifies the price by saying, that's about the price differential to get a hybrid, and this system has the advantage of being transferrable to your next vehicle.
Ryland (05-24-2012)
Old 05-23-2012, 07:30 PM   #2 (permalink)
Who is going to want this thing hanging off the back of their car?
Old 05-23-2012, 07:55 PM   #3 (permalink)
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
+1 to that, it's not even in an attractive fairing or anything!
Thanks for the link though Metro, it's definitely food for thought.
Nissan Leaf driver? Join me in Team Leaf and feel smugly superior about our MPGe
Current Car: White Lightning
Retired Car: Betty White
Old 05-23-2012, 07:57 PM   #4 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
If it doubled my mileage, i would.
The Following User Says Thank You to ksa8907 For This Useful Post:
divedaddy03 (07-17-2012)
Old 05-23-2012, 09:03 PM   #5 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Who wants a big ugly boat tail hanging off the back of their car? Kind of the same idea. Function over form.
I think it's a cool idea.
Old 05-23-2012, 09:39 PM   #6 (permalink)
tortoise's Avatar
number 9 - '89 Geo Metro LSi
90 day: 49.25 mpg (US)
Add a seat, fork and front wheel, you could convert it to a motorcycle.
Old 05-23-2012, 10:21 PM   #7 (permalink)
It's a parallel hybrid in the reverse of how I had considered one. If you had an EV and you wanted to get long range, you could put a small engine on a setup similar to this and drive at highway speeds in a single gear.
I wonder how it deals with turning scrub; assuming that the single wheel is only pivoting up and down?
Old 05-23-2012, 10:52 PM   #8 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Wow, I might try this with my motor I have setting around, instead of selling it.
Old 07-09-2012, 01:18 PM   #9 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
That bloke is already thinking of selling patents.
Apparently he doesn't know the fifth wheel thing has been done before, so there is previous evidence, and nothing to patent.
Old 10-16-2012, 12:16 PM   #10 (permalink)
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
any revision or restructuring or ground built prototype, can and would need a seperate patent to be legit to that specific design... while there have been others to make this same type of system, they are not equal.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
