here is another question for ya , whats heavier, the tire or the wheel , it may make sence to get larger wheels and lower profile tires if the tire is heavier than the rim.. alsoi wonder if the larger the rim the less weight per rim inch?
Not to mention you could also gear up your end ration with a bit taler rim tire combo.
