Old 06-03-2008, 05:10 PM   #11 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
here is another question for ya , whats heavier, the tire or the wheel , it may make sence to get larger wheels and lower profile tires if the tire is heavier than the rim.. alsoi wonder if the larger the rim the less weight per rim inch?
Not to mention you could also gear up your end ration with a bit taler rim tire combo.
Old 06-03-2008, 07:04 PM   #12 (permalink)
Blue - '77 Chevy P/U
it goes steel,,rubber,,alum.
Old 06-04-2008, 12:57 AM   #13 (permalink)
I REFUSE!
thebrad's Avatar
VTEC Express - '96 Honda Civic CX
90 day: 57.72 mpg (US)
Send a message via AIM to thebrad
Around rim weights of under 14 lbs the tires begin to outweigh the rims themselves.
Such was the case when I had traklites, I had 10 lb rims, with 18 lb tires.
Old 06-04-2008, 03:49 AM   #14 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Originally Posted by thebrad View Post
Really curious now, where did you find that weight spec?
I can't find my source any more, but I do clearly remember that the wheel weight of the insight was less then the HX and not much more then the VX and it's a 14" wheel, but the information came from someone who did take the wheel off their car, removed the tire and weighted the rim on a scale that was accurate for trade.
Old 07-10-2008, 06:27 PM   #15 (permalink)
Insight Spare
I wonder if you could use a Insight spare as a everyday wheel. It would way less because it is not as wide as the standard rim. Only 4in. wide. What do you think?
Old 07-12-2008, 01:03 AM   #16 (permalink)
Red Egg - '95 Ford Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Dodge Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
spare wheels maybe, spare tires negative. those are temperary tires that are not for the highway with any load. Some people brag that they used a donut a whole work week and that's awesome for them. Murphy's law attacks me too much for that type of risk.
Old 07-12-2008, 02:18 AM   #17 (permalink)
I was thinking of just using the rim not the tire.Don't know its possible to buy an everyday 4in. wide tire. Just an idea.
Old 07-12-2008, 02:37 AM   #18 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 honda civic Hx
Last 3: 58.02 mpg (US)
Cant rolling resistance increase when you decrease the width of the tire because the same weight is spread over a smaller area?
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 07-12-2008, 11:40 AM   #19 (permalink)
I just refer back to a bicycle. A mountain bike with a large tire seems to peddle a little harder than a road bike with its thin tire and contact patch. Plus I would think the tire and rim would weigh less increasing mileage.
Old 04-19-2011, 10:46 AM   #20 (permalink)
90 day: 57.73 mpg (US)
21.5 lbs, Insight wheel + OEM tire
Ryland - did you ever end up getting those Insight wheels?
FYI, I have weighed a wheel + tire from my new UFO (2000 Insight)
- 21.5 lbs = wheel + tire
- The tires are supposedly 13 lbs new (says Tire Rack: Bridgestone Potenza RE92)
- So, if we say the tire I weighed is ~12.5 lbs (worn nearly smooth)
That makes the Insight rim alone ~ 9 lbs
Christ (04-19-2011)
Reviving a 2000 Honda Insight "beater" Red Hybrids 215 08-10-2017 08:35 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 02:49 AM
Places to get OEM Honda Parts TomO Off-Topic Tech 10 06-02-2009 02:56 PM
Honda insight, doing research, interesting trends NoCO2 General Efficiency Discussion 15 05-06-2008 08:36 PM
WTB: Honda Civic HX Wheels XFi For Sale 2 01-26-2008 08:02 PM
