Thread: Air dams?
Old 05-26-2012, 02:42 PM   #65 (permalink)
ECONORAM
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by woodstock74 View Post
Well I bit the bullet...
"Tested" it, went up and down the interstate to make sure there was no buffeting or anything untoward. At very least it isn't hurting. Unfortunately I don't have any better data acquisition at the moment other than the MkI eyeball and tach vs. MPH reading. So initial look showed we're inching closer to 2600 RPM @ 68 mph. Before I started all this 68 was just below 2800 rpm. Now we're just above 2600 rpm. The tale will be the fill up. Though need to look into a ELM adapter for the OBD. Has anyone tried the Torque app for Android? Sounds like a Scanguage for $20 (about the cost of the ELM adapter, the app is free).
Very nice looking piece. I'm curious to see your results after a couple tanks. I tried something along the same lines, set back from the front of my truck about 6 inches, angled towards the sides... It ended up not helping FE (hindered actually) on a drive from Wichita Falls, TX to Spfld, IL, but that may be because my truck already has A=32 sq ft. I reverted to my original mod config, a splitter that sticks out 1.5", extends back and slopes down about 2" to my front suspension frame, then straight back...
But my handiwork wasn't nearly as clean as your is. Good job!
