05-15-2012, 12:53 AM
#61 (permalink)
T-100 Road Warrior
After 2 tanks of gas, I finally pulled the extra piece today. Just wasn't paying off in the MPG department...it actually dropped.
MPG fer the 2 tanks with the added air dam were 18.17 mpg and 16.88 mpg. I saw 18.25 mpg, 19.03 mpg, and 18.26 mpg prior to this mod. At least it was easy to detach...
Good luck with yer air dam...
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
05-15-2012, 01:59 AM
#62 (permalink)
I've got a kind of air dam/sort-of tire spat design I'm trying out. It's really a full width air dam with a gap in the middle, that wraps around the bumper tire to tire. The gap is in the dead center of the the front roughly 2ft wide. I'll have to get y'all pics when I can. IMO it seems to be working btterr than the full air dam so far, but it's too early to be sure.
I'm on my phone btw so I apologize for any typos.
05-15-2012, 06:01 AM
#63 (permalink)
Tanks!
05-15-2012, 07:55 AM
#64 (permalink)
I was thinking it could fail to work based on the location.
You were allowing air under the car and stopping it, therefore forming a pressure build-up in that area with no obvious means of escape.
On the Corvette an opening to the radiator is provided above the set-back air dam, and the engine bay is also ventilated for flow and or pressure relief.
It looked real good while it lasted, I commend your ability to try something new.
05-26-2012, 01:42 PM
#65 (permalink)
halos.com
Originally Posted by woodstock74
Well I bit the bullet...
"Tested" it, went up and down the interstate to make sure there was no buffeting or anything untoward. At very least it isn't hurting. Unfortunately I don't have any better data acquisition at the moment other than the MkI eyeball and tach vs. MPH reading. So initial look showed we're inching closer to 2600 RPM @ 68 mph. Before I started all this 68 was just below 2800 rpm. Now we're just above 2600 rpm. The tale will be the fill up. Though need to look into a ELM adapter for the OBD. Has anyone tried the Torque app for Android? Sounds like a Scanguage for $20 (about the cost of the ELM adapter, the app is free).
Very nice looking piece. I'm curious to see your results after a couple tanks. I tried something along the same lines, set back from the front of my truck about 6 inches, angled towards the sides... It ended up not helping FE (hindered actually) on a drive from Wichita Falls, TX to Spfld, IL, but that may be because my truck already has A=32 sq ft. I reverted to my original mod config, a splitter that sticks out 1.5", extends back and slopes down about 2" to my front suspension frame, then straight back...
But my handiwork wasn't nearly as clean as your is. Good job!
05-26-2012, 03:51 PM
#66 (permalink)
maybe put the dam only infront of the tires/a-arms.
05-26-2012, 11:45 PM
#67 (permalink)
halos.com
After my negative FE results above, I decided to revert to something more akin to the coveted 1969 Dodge Charger Daytona. It has the same (or nearly the same) frontal area as the "normal" 69 Charger, but the aero shape gives it a MUCH better Cd. The Plymouth Superbird and Dodge Charger Daytona, supercars (15% better...)
06-20-2012, 07:48 PM
#68 (permalink)
06-20-2012, 08:23 PM
#69 (permalink)
Sport Compact Driver
Any success?
06-20-2012, 08:30 PM
#70 (permalink)
Originally Posted by Sporty Modder
Any success?
Yes I think so. My MPG has trended upwards since it's introduction. It certainly didn't hurt.
The Following User Says Thank You to woodstock74 For This Useful Post:
