Thread: Air Tabs
Old 05-28-2012, 12:10 AM   #35 (permalink)
ecomodded
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
Originally Posted by ksa8907 View Post
What if you just put some ordinary round magnets on your car instead?
Put them on your dashboard and you will SEE a gain
(a small weight gain)
I personally like the shark fin style air tab which is what they use on aircraft. The aerodynamic drag of these will be minimal, having a very narrow profile they are designed for high speeds.
Like the 747-400 has a cruising speed of Mach 0.85 (567mph). It's maximum speed is Mach 0.92 (614mph).
I hope not to give a wrong impression of the effectiveness of these at lower speeds, in practice the airplane wing air tabs allow a plane to take off sooner as well as using less hp which= fuel. the 747 takes off at 120 mph. Smaller planes with lower take off speed also use air tabs, the 747 was just an example.
Save gas
